jbull
- PDS22SISBRSS
- GE
- 6-10 years
Hi, everyone
So my freshfood and freezer both had failed, with compressor hot and not starting, and compressor fan stopped.
After some googling I have replaced a relay and still the same, so I'v called a repair man to do a diagnostic.
He was sure it was motherboard.
So I bought CB10942 which is a replacement or equivalent part to WR55X10942Pwhich is recommended replacement for my original board of WR55X10416.
I replaced the board. But only compressor fan starts to work but compressor still doesn't start up( doesn't cool). If I put my hand on it, it is warm and it is whirring.
On installation manual for the board,
For bottom freezer type like mine,
It says to cut 2nd prong on J1 harness connector and skip if you don't have line on 2nd prong. And I do not have a line there.
Also it says to cut a green wire if capacitor is wrapped with power line to the harness (again for bottom freezer types)
And my black capacitor is separated out, so there is no green wire. Only green wire from harness goes to the ground where it meets other green that goes to compressor.
It has been week without fridge in California where temperature is 95!
Would somebody please help!
