Malfunctional JCP Microwave
Daniel
Northern Virginia
JC Penny
Hi all,
I have this JCPenney microwave in my basement, left over from my house's previous owners. It had never functioned right since at least the day we moved in 13 years ago. What the problem is, half the buttons don't work, that includes the start button. However when you plug it in, the digital screen kicks on and you can hear a faint clicking noise as you plug it in. The light bulb inside works as well.
Could this be a blown fuse inside the microwave? I think part of its decline is the fact they installed in in the wall. The back of the microwave is in a closet, which appears to be somewhere around 4' by 2'6? The door to the closet was shut when the previous owners still lived here. So maybe there wasn't enough ventilation and a fuse blew?
Here are the specs in case they're needed:
Model Number: 863-5525-70
Cat. Number: 863-2564
Manufactured: June 1987
Hertz: 60
Volts: 120
Amps: 12
Any help would be greatly appreciated!
-Daniel
Nope, entire unit will go dead when the internal fuse lets go.
That more often than not is a key panal issue....and yours has come up NLA = shopping time.
Maybe...a mid-80's microwave key panal that still works...stranger things have happened. ;)
