Maytag 2000 Series Washer MHWE201YW00 error codes E1 F6 ...what's wrong and whats the fix ?
timmyt
MHWE201YW00
frontload washer maytag 2000 series model MHWE201YW00 error codes E1 F6 ...what's wrong and whats the fix ?
F6E1 error is: The communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Close the door.
Select any three different keys (except POWER).
Individually press these in a sequence of 1, 2, 3 and then repeat this sequence two more times. (1-2-3 1-2-3 1-2-3)
This sequence must be completed within 8 seconds of the first key press.
Remember the keys and order pressed.
If you did it right, all the LEDs will turn on for 5 seconds and the error will be displayed.
Momentarily press the 3rd key to display the next error code
See if you have any more errors.
