Maytag A207 washer - not advancing thru the cycles
TetraLewis
Calgary
A207
My mom has a Maytag Washer A207. It was not advancing thru the cycles, so I purchased a replacement timer switch. the original timer switch part # was 2-4454. The replacement timer switch I purchased and installed was 2-04454-2. Although the parts were not identical, I matched up all the numbers when installing. The new timer now advances but it will stay in the wash cycle indefinitely while the knob advances. If you push the knob in and stop the machine and advance it to the spin cycle it will perform that task.
Any ideas on how to complete the repair?
A new (ie. UNused) one??
The slight variation in the number on the part is not likely a concern. The numbering difference just relates to an updated timer design by the timer manufacturer.
It sounds to be like you instead a defective timer.
JMO
TetraLewis
Calgary
I purchased the replacement timer on ebay so not new.
So likely I replaced a faulty timer switch with another faulty timer?
The replacement timer advances
I don't see any other way what you said can happen.
There's more to a timer than just advancing. There are contacts and cams inside that have to operate properly to switch the various functions. It sounds like the contact for the wash function is sticking or loose, or the cam that actuates it is damaged.
TetraLewis
Calgary
And is all that inside the timer switch? So if I repurchase a new timer switch I will hopefully have the problem fixed?
Those are all components inside the timer, yes. Here's a pic of the interior of one, simpler timer.
As I said, I don't know of any other possible cause for your symptoms than a defect in the timer itself. If a fully functioning timer is installed, those symptoms should not occur.
A "new" timer is getting rare to find but this supplier still shows stock.
LINK > WP204454 replacement Maytag 2-4454 Timer
It should also be possible to have your original timer professionally rebuilt/remanufactured if you send it to a timer repair company. It would certainly be a better option than buying a "used" one. Rebuilt ones can sometimes experience problems as well so techs usually leave that was a last resort.
JMO
