- MAV7200AWW
- Maytag
- More than 10 years
The washer will fill fine but will not spin or agitate or drain. I did check that the motor spins freely. I was able to rotate the motor with the belt on as well and all the pullies moved fine. I can't move the inner drum by hand clockwise or counterclockwise though.
I also noticed when I tried to start a spin cycle the motor would attempt to rotate but would only get 1/16 of a turn before stopping. I did see in another post that it might need the thrust bearing replaced but that is for a different model Maytag washer but about the same age. Am I on the correct path or is there something I am missing. Thanks for any help.
