Maytag Bravos MVWX600XW1 stops agitating randomly and then shuts off
repair_newbie
NC
MVWX600XW1
Sometimes the washer works perfectly and completes the full cycle. Other times, it will fill with water and agitate for 5-10 minutes, and then everything stops and it just sits there for a while, and then turns off with the "wash" light still lit up, and all other lights off. I went in diagnostic mode and the only error code was one that said something like "Washer was put through more than one cycle without opening the lid".
But this I did on purpose during my testing, it got through a full cycle so I just started the next one up to see if i could get it through another one. So in other words, the error code is not helpful. I put it in manual test mode as well, where it tests all the functions. (hot water, cold water, agitate, spin, etc) and everything was working 100%. Any ideas what would cause it to just stop agitating in the middle of the cycle and shut off?
It sounds like the control board is malfunctioning, since all the parts work fine in manual test mode, and also since you are getting no error codes.
W10480131 Electronic Control Board
