FIXED Maytag Bravos MVWX655DW1 Washer is currently stuck in wash mode and won't reset.
Jacksniper
MVWX655DW1
The washer quit working with a loud buzzing noise in the wash cycle. When I unplug/plug,for more than long enough, it returns to the wash cycle blinking. If I try to run the cycle after sitting for a couple minutes the buzzing returns. If I cancel the cycle the buzzing noise also returns and won't go into diagnostic mode.
Where exactly is the buzzing noise coming from?
If you can't get into the diagnostics, then the main control board is malfunctioning.
Here's the main control board for your model: Control Board W11116592
Jacksniper
Solved.
There was nail jammed inside of the drain pipe, so it would try to drain and get stuck.
That's good to hear.(y)
Are you still not able to put the machine into diagnostics?
