FIXED Maytag bravos washer error code ld
Shoe0402
Pennsylvania
NEED
Hi everyone my washer the other day was finishing up rinse cycle and it got an ld error code. The old I did before our daughter must have thrown a diaper in and it exploded I sucked the inside out of the tub with a shop vac but thinking maybe something got inside the pump? I unplugged it for 5 min and plugged it back in and I hear I’m assuming the pump humming but nothing else happens then after a few minutes it shuts off then it comes up with the code. After I power it off it still bums for a little bit maybe a minute or so. Does this seem like a clogged pump or something else?
Howdy Shoe,
We need the model number of your washer first, the model number tag should be inside the door.
Yes, it sounds like you have a foreign object stuck/jammed in your drain pump, or your drain pump bearing has seized up.
Shoe0402
Pennsylvania
Hi jake
I actually ripped it apart today and found some socks inside the drain pump. It is working like new now. I also cleaned it really good. Thanks for the response
Sounds good Shoe, glad that's all it was.:)
Texas
I have a Maytag bravos x. I replaces the lid lock switch and pump. Will not go to next cycle. Code comes up again for switch and pump
Click here: Appliance Parts
