FIXED Maytag bravos x Washer MVWX700XL2 barely agitating and won't spin
Janetzke23
Georgia
MVWX700XL2
Good evening. We recently replaced the pump and shift actuator and things were working great. My washer won't agitate or spin. Its throwing f7 e1 and f7 e7. I cleared the codes and it isn't working. I was thinking coupler or motor replacement. Any insight
You have a defective shift actuator, where did you get it from?
Because look at this thread:
He replaced the same exact shift actuator as you did and it fixed it. He has the same exact model you do and same error codes.
Here's the shift actuator for your model you can order here:
WPW10006355 Shift Actuator
Janetzke23
Georgia
Il order another one. We just replaced that, the drum seal, and the pump and it was working fine. I'm gonna order another motor. Could this be a transmission issue?
Janetzke23
Georgia
I ordered the shift actuator (both oem) and its still not moving. I'm thinking it's the transmission
Clear the error codes, and then do a drain and spin cycle, or rinse and spin cycle and if that doesn't work, see what new error code/codes you have now.
F7E7--->MOTOR UNABLE TO REACH TARGET RPM
Fault is displayed when basket speed sensor detects that target RPM was not reached.
See TEST #3: Drive System, page 13
• Mechanical friction on drive mechanism or basket (clothing between basket and tub).
• Weak motor or run capacitor, or no connection to run capacitor.
• Load off balance. Clothing should be distributed evenly when loading.
• See TEST #3b: Drive System–Motor, page 14.
Also unplug the machine and remove the motor capacitor and see you have a big bulge in the capacitor.
Here's the capacitor for your model:
  • W10468342 - Rev C.pdf
Janetzke23
Georgia
I did clear them but didn't think of rechecking when I tried to run it earlier. When I get home I will run the diag mode again. I did pull the actuator and it looks like a bunch of rusty dust is coming from the transmission. I did replace a tub seal that had leaked so I am wondering if water got in the transmission and made that faulty. I will update in a little while
In your video I only hear the drain pump running, not the motor to make it spin.
Make sure the main drive motor that turns the transmission pulley is running while the drain pump is running too, another member found a bulged capacitor causing the main drive motor that turns the transmission pulley not to run properly.
Janetzke23
Georgia
Update. Replaced the transmission, motor, shift actuator, capacitor, all the transmission pulleys and plastics that go to the pulley, the plastic hub. It finally works but somethings squeaking pretty good. Any idea? Sounds like the drum.
Remove the agitator and run it and see if it still makes that same squeaking noise.
Janetzke23
Georgia
So it doesn't squeek with agitator off. But is this crazy spin normal for the agitator. The transmission was crazy tight to turn manual vs the new one. It ran a complete cycle but it didn't spin all the way dry. I did all synthetic light material so it's not overloaded by any means. The agitation is so nuts in the beginning its spinning the load out of balance
  • 20210803_082152.mp4
Janetzke23
Georgia
And to add we don't run our washer outside normally we just are doing it to run during the fix issue. The previous tub seal went and soaked my floors so it's just in case
Janetzke23
Georgia
I pulled the hub to check as it seems it can strip. Teeth looked good and I tried the old one and same issue.
The transmission you got is bad, where did you get it from?
Here's the gearcase(transmission) for your model: W11454372
Janetzke23
Georgia
I got it a certified oem place an hour and a half from me. I cloth diaper and need it as I'm already blowing through my monthly budget from The laundry place. Is there any other part it could be. I bought all new oem parts to avoid failure and I'm kicking myself.
Janetzke23
Georgia
Mod number
Then its defective, have the place you got it from take it back and give you another new one for free, you should have a warranty on it.
Janetzke23
Georgia
I called, they are going to 2nd day ship me.one free and return the other one free. I have amazing luck. I so appreciate your help. I assume the squeek was the internals pooping the bed.
Janetzke23
Georgia
New gear case is in and this is now making this sound in the calibration mode. Stopped it right away
Janetzke23
Georgia
Update, I put all of the factory original pulleys and such on. The gear with the spring was so tight it wasn't allowing the cupling to move
What gear with the spring? You mean the plastic splutch cam?
Here's the splutch cam kit for your model:
W10721967 Splutch Cam Kit
Where are we at now then?
