- MEDB835DW3
- Maytag
- 6-10 years
My Maytag dryer (MEDB835DW3) is broken. I've owned it for somewhere around 6 years? The control panel still powers on and lights up, but when I try to start a cycle it just makes a "click" noise like a relay pulling in. The drum does not spin.
I checked the voltage at the four pin wall plug. It is 120 VAC from either leg to neutral or ground. It is 240 VAC from phase to phase. I have not yet pulled the plate off the back of the dryer to confirm proper voltages there.
I do have an error code F4 E1. I understand this is a "Heater 1 Failure or Connector Problem". The guide suggests this "Indicates no voltage detected at the heater relay." It instructs me to, "Unplug dryer or disconnect power and check that the wires are plugged into the heater element(s) and the relay(s) on the ACU." I have unplugged the dryer and disassembled the front panel. All connections around the heater appear properly connected. I also looked at the main control board. Nothing appears loose or unplugged here, either.
I attempted to run the service tests. It almost immediately went into a display where the following items cycled:
L2, 000, L1, 000, Htr, 000, Air, 003
While I had the front removed, I checked the thermal fuse. It has continuity. I also check the thermistor. It is roughly 9k ~ 10k ohms when cold, and the resistance drops as it is heated. It is marked "R60-2.6K".
I will pull the main control board, and reseat all the connectors next. Any other recommendations?
