FIXED Maytag Centennial MVWC300VW1 Clutch Bad?
gillisk976
Boulder
MVWC300VW1
Hi Folks,
I'm new to the forum. My Maytag Centennial sounds like the agitator is slipping and not rotating as much as it should during the wash cycle. It's also quite loud as you can see in the video. The clothes are not really spinning too much either. I've read that the clutch may be bad. I did lay it on its side and could not find any loose bolts.
Here is a video of it during the wash cycle:
Here is a picture of the underside of this beast. Any help is greatly appreciated!
Its not the clutch, the clutch is only active during the spin cycle, so its either your agitator or transmission.
Remove your agitator and do a test run with NO CLOTHES in it and see if it still makes that noise.
Here's the agitator for your model below, when you click the link to it you will see a video on how to remove it.
WPW10093672 Agitator
gillisk976
Boulder
Hi Jake,
I removed the agitator and did a test run with no clothes and the noise was gone. There is one bolt that holds the agitator in. I thought maybe it was just loose so I put the agitator back in and tightened the bolt and still had noise. To me it looks like the splines on both the washing machine and the agitator did not really have any wear. What is failing in the agitator to cause the noise? Thanks so much!
Best,
Kenny
Ok Kenny,
Now what you will want to do is separate the upper agitator from lower agitator and see if the 4 agitator dogs are worn out, thus making the upper agitator strip and not grap the cam properly.
When you click the part link to the agitator repair kit you will see a video on how to separate it.
Here's the agitator repair kit for your model you can order if needed:
285811 Medium Cam Agitator Repair Kit
gillisk976
Boulder
Hi Jake,
I think my agitator dogs are worn out. What do you think? I've included a picture of each one.
Kenny
Yes Kenny, they sure are.
That agitator repair kit I posted above includes 4 new agitator dogs.
gillisk976
Boulder
Hi Jake,
I just ordered those parts. Thank you so much for your advice. I'll let you know how the parts install goes.
Kenny
Ok Kenny, sounds good.
gillisk976
Boulder
Hi Jake,
It seems that the cam agitator repair kit did the trick. Thanks for your easy to follow advice and for suggesting the correct parts for my Maytag washer. I did make a donation.
Best,
Kenny
Excellent Kenny, glad to hear the cam agitator repair kit fixed it. (y)
Thanks for the update and donation!
