Thanks Jake. I had it unplugged overnight. I plugged it in and cleared the fault codes. Initiated the Drain/Spin cycle. The pump ran and it drained, then the lid lock light went off, no spin, drained again, at which point I lifted the lid and all the lights went off. The spin light was on throughout this process, which took 30 minutes.
I checked the Fault/Error codes and can't make sense of them (I have the tech manual). The only code is the Done light is on, if I rotate counterclockwise to check the prior codes I get the Spin light on, then the Spin and Done lights, then only the Rinse light.
I tried to run another load on the Normal cycle, think maybe it reset itself. It didn't spin while Sensing, the tub did fill with water but it's not moving when the Wash light is on. Once it drains I'll have to take out the wet clothes. Last night when the tub was empty I was unable to turn it from the inside by hand. When I replaced the actuator in January everything worked, but the Spin did seem to be faster than I previously thought.
Thanks again.
