- DE303
- Maytag
- More than 10 years
I have an old Maytag dryer, model number DE303. I don't know how old it is other than 'very'. I've had for 15 years and it wasn't even close to new when I got it.
It has developed two problems I can identify. They started, as far as I can tell, at the same time, so I presume they have a common cause. The symptoms are:
1. The timer / cycle selector does not advance. I can put a load of clothes in, start the dryer, and it will run, as far as I know, indefinitely until I turn the dryer off manually by turning the cycle selector knob to "Off".
2. If the dryer cycle knob is on any position other than "Off", the heating element turns on. It doesn't matter if the tumbler is stopped. It doesn't matter if the dryer door is open or closed. At all times, if the cycle knob is set to anything other than "Off" and the dryer is plugged in to power, the heating element is on.
Given this machine's age, I am aware that getting replacement parts might be impractical, but I thought I would at least attempt to repair it before I toss it, because it's been a good machine for a very long time now. What defective component would cause these two issues?
