Distance22
- MDB4949SKZ
- Maytag
- Less than 1 year
Purchased this new and just installed but it leaks while running. It leaks from the front left and front right side. Nothing is leaking under the dishwasher…it appears to be leaking from the door seals but they are not ripped or torn. It appears to be leaking from the top corner seals and then draining down to the floor. The corners do look a little warped, maybe? I even tried pulling the gasket off and resetting it. It’s almost like the door isn’t fully sealing against the gasket. The dishwasher is level.
I have a Maytag tech coming out but they can’t come for nearly a month. I attached pictures of the seals, does anything look off?
