Maytag Dishwasher MDB6769PAS3 Beeping Randomly and All Lights Blinking, Help!
Chris119
New York
MDB6769PAS3
My Maytag Dishwasher model MDB6769PAS3 has been beeping randomly a lot. All lights on the control panel are blinking and not responding. I have unplugged it for days and left it alone. When I plug it back in, it beeps and blinks like crazy. Any ideas on how to troubleshoot? Thank you so much.
Hi, Yes, it sounds like a short in your keypad control panel and causing this problem.
Do this below:
- Unplug dishwasher or disconnect power.
- Disassemble door and disconnect keypad connection from control board or LCD display module.
- Verify all other connections to control board are made.
- Reassemble door, but do not close door.
- Plug in dishwasher or reconnect power.
- Wait at least 7 seconds for control board to power up completely.
- Close dishwasher door and monitor control board response:
A. If control board is OK, it will respond by turning on the drain motor for 2 minutes. Replace keypad and console.
B. If control board is not OK, it will not turn on drain motor. Wait for at least 10 seconds. If there is still no drain response, then replace control board or LCD display module (whichever one the keypad was connected to).
Here's the key control panel assembly for your model you can order:
WPW10475774 Panel-Cntl
W10595568 Electronic Control Board
This video shows you how to access those parts:
