Maytag Dishwasher MDB8989SHZ top rack rubbing trim
jrkmo1
St Louis
MDB8989SHZ
Recently I noticed that the top rack of my dishwasher is rubbing against the rubber trim when closing. It's the grey plastic piece that allows you to raise/lower the rack height that is touching. If I open or close it carefully, by slightly pulling the rack to the right, then I can avoid the trim. If not, it either gets stuck or rubs against the trim noticeably enough where you feel it.
We recently had new cabinets and a countertop put in. The dishwasher stayed in place. Is it possible that the dishwasher just got attached to the new countertop a little crooked and that caused the alignment issue? The trim/seal looks good at this point. It's not bulging.
It's almost as if the rack itself or the rails may have been slightly warped. Nothing happened that I'm aware of and there's nothing obvious to me that stands out as crooked or anything like that.
Any ideas on how to fix this issue so the rack opens and closes without contact?
