tastebuddy
- MEDX655DW1
- Maytag
- 1-5 years
Maytag Bravos MEDX655DW, 3.5 yrs old, purchased at Lowes. Push to start style. It wouldn't turn on. I did a few spot checks, and replaced the thermal fuse and cleaned out the back and hose very well (it was not clogged, and lint screen is always cleaned after every use).
After replacing thermal fuse, I set it to timed dry and it came on! it ran almost thru to the "stop" but stopped short of the Stop position and would not come on again. A day or so later I tried it again, different timed setting, and it came on but only ran for about 5 minutes.
I checked the door switch with a multimeter and it tested bad so I replaced it. After replacement, I checked the light, it was on with the door open. I then set it to timed dry , shut the door and it immediately came on! it ran for 30 minutes and stopped, but again just barely short of the "stop" location on the timer dial. It would not come back on.
I'm not sure what to look for next. It is heating and the blower is blowing full blast thru the vent. I checked just now and when I open the door the light does not come on.
