maytag dryer heats but motor doesn't turn
fred9
imported post
When timer is started the machine heats but motor only humms. (maybe the heat element is humming?) I replaced the motor and no change. I watched the motor shaft from the back when the machine was started and shaft didn't turn.
The door switch seems to work - the low humming stops when the door is opened.
Any other items I should check? Thanks, Steve
imported post
If you can post the model# that would help us as maytag does have different type models.
Could be a timer issue ora start relay problem.
Motor turns ok by hand when its installed in the dryer?
fred9
imported post
Model # LDE9314ace
Yes, motor turns by hand when installed.
Where is start relay? THANKS, Steve
imported post
Some Maytags had a start relay in the console, but as Jeff said yours does not.
You have a start switch on the motor itself, but if you already changed the motor then it should have come with the new motor as a assembly.
That Link Jeff gave you should help with your dryer problem.
fred9
imported post
It was the thermo fuse right in the front. So I wasted over $100 for the motor BUT it did force me to learn how to use a Multimeter - I learned how to check voltage - 220 and 110 and I learned how to check "continuity".
Thanks for all your help.
Applianceaid.com was VERY helpful!!
Steve
imported post
Thankx for the update!! :)
