Maytag Dryer making loud noise
harryp
maytag
Hi, newbie to this forum:
I have a 5 year old Maytag dryer that makes loud clanking type of noise when running. In fact when the dryer stops the noise continues for a second or so longer... Do you think I have a belt slipping??
Heating is not a problem at all.
Thanks in advance,
Harry
*Sounds* like ( no pun intended ) a broken fan blower. no model# posted on which Maytag dryer you have, a couple of common blades....
Blower Wheel Y303836 Order now for same day shipping. 365 day return policy. RepairClinic.com
Blower Wheel commonly used on Maytag style gas and electric clothes dryers.
Blower Wheel 31001043 Order now for same day shipping. 365 day return policy. RepairClinic.com
Blower wheel, 3-1/8” deep, 8” fin diameter, 7-1/8” hub diameter, 20 standard fins, ½” diameter motor shaft, 7/16” motor shaft diameter to flat side of shaft. Spring clamp not included. Series B10 only
Blower Wheel 53-0106 Order now for same day shipping. 365 day return policy. RepairClinic.com
Blower wheel, 3-1/8” deep, 7-1/2” fin diameter, 6-3/4” hub diameter, 20 standard fins, ½” diameter motor shaft, 7/16” motor shaft diameter to flat side of shaft. Most commonly used on Norge/Admiral/Magic Chef
The "D" shaped part in the middle of the fan blower rounds out and the blower makes rumbling noises.
