FIXED Maytag Dryer MEDB765FW0 wont heat
evanjs
Texas
MEDB765FW0
I have a 4-5 year old Maytag MEDB765FW0 Dryer and all of the sudden it wont heat. Everything else is working properly. Is there a quick way to determine if its the heating element? thanks
So the dryer is running but not heating? Did you check your dryer breaker in your home breaker box to make sure one of the dual breakers is not tripped?
You can Ohm test the heating element and thermal cut-off and high-limit thermostat, you'd need a multimeter. Make sure you disconnect power to the dryer first before accessing/ohm testing those parts.
Here's the thermal cut-off for your model:
Thermal Cut Out Fuse Kit 279973
Here's the heating element for your model:
Heating Element Assembly WP3387747
Perfect, thank you. The breaker is fine, so I will ohm test the parts today.
Your welcome.:)
Do you know how to access those parts?
Excellent, good job replacing the heating element.(y)
