Maytag dryer won't start, motor humming and timer button cannot be pressed down
BenChang
imported post
My Maytag dryer (Model # is: Maytag DE608) is a pretty old one. Now it won't turn (acctually it turned a little bit and stopped) and the timer button cannot be pressed down.
I did some test. When I lose the belt, the motor turned and the timer button could be pressed down. Then I took the drum out. I tried turning roller, pulley and motor with hand. One of the back rollers, pulley and motor were hard to turn. I oiled them and put the drum back. Still, whenever I fastened the belt, the motor glided a little bit then stopped.
I am not so sure where the problem is. It seems the motor is OK. Please give me some hints. Any suggestion would be appriciated.
Thank you!
BenChang
imported post
You are right. The motor looks bad. I am going to replace that.
Thank you
imported post
If you get a chance, let us know how the repair goes.
BenChang
imported post
I want to replace the motor.
But on top of the shaft, that little thing (I think it is called pulley), I could not take it off. It was too tight to take the screw off. Beside the shaft turned when I twisted the wrench.
How to take it off?
imported post
**But on top of the shaft, that little thing (I think it is called pulley)**
Motor pulley?
Motor pulley and set screw
If yes....these can be VERY tight and may not come off....I usually bring a new one with me "just in case"....you can try tapping on the set screw with a hammer or try a little heat on the pulley to loosen the set screw up....1/2 of the time they will not come off for me either.
