Maytag Gas Oven - oven startup/popping problems
kpd
imported post
I am starting to regret purchasing all new Maytag appliances about 3 years ago!
Hello all - yet another Maytag problem from me......
My Maytag oven uses propance for fuel. Two things are going on with this unit.....
Problem #1. When I turn on the oven, the temp will stay at about 135 and not increase. The only way that I can get the overn to increase to the desired/set temp is to turn on one of the burners on the top of the stove. Usally as soon as I turn on a burner, I hear the oven's burner kick in and the oven will then heat up to the desired setting.
Problem #2. While the oven is on, I will occassionally hear the sound of gas igniting - - - sound like the sound you hear when you turn on a gas onthe stove top and ignition of the gas is delayed (singed armhair - if you know what I mean).
I would appreciate the group's assistance on these issues.
thanks,
Kerry (The SadMaytag Owner)
