- LAT2500AAE
- Maytag
- More than 10 years
Both stopped and a minor burning smell. Everything else appears to work fine. Water enters and drains. The panel appears to work and so does the lid. I have replaced the belts and it still doesn't agitate or spin. I have checked that the other 2 pulleys move freely. My next step is to remove the motor and replace the rollers & springs. This is where I am at. Motor removed. Cannot remove the drive pulley as per instructions. The set screw will not turn with an Allen wrench. Have lubricated it and it will not turn to release the pulley. I need any help in how to loosen the set screw and remove the pulley without damaging the shaft. Any help would be appreciated. The set screw is no longer available but does come in the replacement pulley. Is there anything else I need to check for what is wrong with the Maytag. Thankyou in advance.
