Maytag M1TXEGMMYB01 freezer at 25F refrigerator at 40F
severs
Tulsa, OK
M1TXEGMYB01
A month or so ago, this unit starting clicking every second or so for about a minute once a day in the evening (that I noticed). Actually it sounded more like a click/knock. Eventually it would give up and the fridge would go silent, then restart after a while.
I didn't notice any change in cooling performance, until yesterday I noticed items from the freezer were not frozen solid, and liquids from the refrigerator were not as cold. I checked and the freezer is about 25F and the refrigerator is 40-45F.
The compressor is running and the fan is blowing, but it is very warm and the surface measures around 115F at the lower part to 140F at the top. As an aside, I found that a family of mice had made a home in the back of the fridge. I can't see that they had chewed through anything.
I blew everything out of there and off the coils with a leaf blower, with no change in cooling performance. I have not checked the evaporator coils yet. Any ideas or help would be much appreciated.
Do you hear the freezer evaporator fan motor running inside the freezer section?
If so, then remove the back panel inside the freezer and take a photo of your evaporator coil and upload it here, we need to see the frost pattern on it to determine the problem.
This video below shows you how to replace the evaporator fan motor, but you don't need to replace it if its working, I'm just posting the video to show you how to remove the back panel inside the freezer to get access to your evaporator coil.
severs
Tulsa, OK
Hello Jake, thanks for your reply. The evaporator fan does run. Here is a pic of the coils. I'm assuming that chunk of ice is a problem:)
severs
Tulsa, OK
As a status report, I melted the ice, put everything back together, put the half frozen food back in, and plugged it back in. It's been a couple of hours and just down to 32F in the freezer so far.
Per your photo, you have a sealed system problem.
The sealed system consists of the compressor, condenser, evaporator, heat exchanger, filter/drier and refrigerant. Common problems with a sealed system are bad compressors, refrigerant leaks, and system restrictions.
Sealed system repair costs will often exceed the machines value.
It should be at 0 degrees F in 2 hours, that also proves its a sealed system problem.
Your welcome.
