Maytag MDB7759AWS2 - Auto Clean Plus, heavy, and normal flashing + steam clean not flashing
tparks99
TX
MDB7759AWS2
I have a Maytag MDB7759AWS2 that recently stopped working, and is instead flashing the auto clean plus, heavy and normal buttons. The steam clean button is illuminated but not flashing. Pressing any of the buttons doesn't do anything. I replaced the control board, but that didn't help. I also replaced the control board previously for a similar issue around 6 months ago, which fixed the issue at that time. I think the next step would be to replace the control panel, but before I spend more money on it, I wanted to see if anybody else has had the same issue or not.
Any thoughts would be greatly appreciated!
Yes, the problem is your control panel, seen this many times on my service calls.
Here's the control panel keypad assembly for your model you can order:
WPW10199790 Panel-Cntl
tparks99
TX
Hey Jake,
Thanks for the reply! I've ordered the replacement control panel, which should be delivered tomorrow. I'll follow up after I install it.
Thanks again!
Sounds good, yes keep us posted.:)
