Carpediem410
- MED5500FW2
- Maytag
- 1-5 years
It is an electric dryer about 2 years old.
If I put laundry in on the normal cycle, it starts with 38 minutes on the timer, then shuts off after a few minutes. The laundry is still wet.
I tried the timed dry cycle - it runs for the allotted time and heats and the laundry is then dry.
The control panel says good air flow. The lint screen is clean. The vent outside is not blocked and is working fine.
The moisture sensors appear to be clean and I have never used dryer sheets.
Before I try taking the machine apart to check the connections on/replace the moisture sensors, could it be anything else?
Should I try running any other loads to narrow down the issue?
It is a dryer that steams although I haven’t used the feature for a long time.
Thanks.
Thanks.
