bveenvliet
- MGS8800FZ0
- Maytag
- 1-5 years
Hi everyone, I recently replaced the main control board in my Maytag Gas Range MGS8800FZ0 [approx 4 yr old] and the display is blank.
History:
My main control board was destroyed by a mouse who found warmth [photo attached] and I replaced it with a new OEM part from a reputable company.
New part number of the new/old control board W10759301.F
Problem:
Now everything seems to work fine, except for the display that is completely blank.
I've tried pressing and holding the settings/clock for 3 seconds.
Things I've tried:
Buttons beep when pressed.
If I push Bake - 4 - 0 - 0 - START, I hear gas flowing, the oven elements light and it gets up to temperature and later hit CANCEL, it turns off.
All connections to the board [especially the green display board wire] are good.
Stovetop elements light and work fine. Oven light button works and light goes on/off when you open/close the door.
I tried disconnecting the 11 wire green connector from the display board to the control board and did multimeter continuity check of all 11 pins and they're all good.
I have removed and examined the display board and there is no visible damage or black/smoked components on the display board. Looks brand new.
So I don't know if the new board is defective or the display board [W11122852] is defective as well.
I'd like to bench test the display board or check voltage on the TP8 - 11 pin connector on the main board to see if that is the problem.
I've checked the Service manual and wiring diagram and not sure what TP7/TP8/TP9/TP10 voltages should be?
Please help, thank you very much.
History:
Problem:
Things I've tried:
