Maytag MHW8200FW0 washer gets stuck at 11 minutes in the spin cycle, just keeps spinning
Bmangambit
Portland
MHW8200FW0
I have cleaned out the pump filter, run the washer through diagnostics mode without any error codes (from what I could tell. it just got to diagnostic cycle c08 and shut off mid spin). Whether I do a load of laundry or just run a rinse/spin cycle, when it gets to 11 minutes it just spins indefinitely. Pump/drainage issue, or timer issue?
Bmangambit
Portland
Thanks for the help! New control boards are not cheap, is there a pretty high likelihood that this is the problem? I wasn’t able to find a lot of other people experiencing a similar problem so did not find out much doing research on the issue
C08 is the last step of the quick diagnosis. I'm 90% sure the control is the problem. Run the service diagnostic cycle and check for any error codes. The tech sheet should be in the console. Let me know if you can't find it and I look for it.
Rick, I located the tech. data sheet for it. I'm attaching it below.
  • tech-sheet-W10775510-RevA.pdf
Anytime Rick!
Bmangambit
Portland
Unfortunately, I was not able to find a service guide or tech sheet for my model when I opened up the panels (it was a bit frustrating, as I’ve always been able to find the tech sheets for my previous washers inside). Was able to find online how to run the the quick diagnosis, but do not know how to get the washer to give me any error codes. Thanks so much for the help, I think I will be getting the replacement control soon.
Select any three buttons (except power) and follow the steps below
Remember the buttons and the order that the buttons were pressed.
Within 8 seconds press the buttons like this: 1-2-3 1-2-3 1-2-3
If you did it right, either "888" wil be in the display or a flashing error code
Momentarily press the 3rd button you picked to move to the next error code
Press and hold the 3rd button to clear the error code
Bmangambit
Portland
I did another quick search and found the service guide in a place I didn’t expect. So I’ll take a look and see if I can see any error codes and will let you know
Bmangambit
Portland
So no error codes. I’m going to try a new control board and see if this fixes the problem. Thanks for the help!
@Bmangambit I uploaded your tech. data sheet in post #5 do you see it?
JoelM8443
Hooks, TX
Could you confirm if the new board fixed your issue? I have 2 Maytag MHW3505FW0 s that do the exact same thing. Pump and wiring is fine. LED on ACU indicates that it’s in working order. Have been stumped for months. A response would be amazing. TIA
