Maytag microwave making loud noise and not heating
ssandheinrich
Cooper City
MMV4205AAQ
When trying to heat something in the microwave, it makes a loud noise but the food item is still cold. The lights come on, the table rotates and the time counter descends. Everything seems normal except the temperature of my coffee. :(
Often...
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
