Maytag Model MFI2665XEM6 not making ice need tech sheet
MSgtnobody
NY
MFI2665XEM6
Want to try to test it in Diagnostic mode but dont have a tech sheet for guidance.
I don't have it for this model, I will ask our tech bigbuck if he does.
MSgtnobody
NY
thank you, completed Service Test - 25 Water dispensing and icemaker fill test. When I pressed water dispence I got the number 1 on 2nd digit. when i pressed ice dispencer I got a #0 then dbl 00's started to blink?? I havent tried to jump t & h yet.
Thanks bigbuck!
--->Simulate an icemaker fill. Then the icemaker will show icemaker fill status. Press the water pad to initiate the water dispense.
NOTE: To initiate icemaker fill jump icemaker thermostat T and H.
Yes, these ice makers are prone to fail in sending 120 volts to the ice maker side of the water inlet valve. I already replaced 3 of there same ice maker kits for this exact same problem:
Read post #2, then read post #5 on HOW TO JUMP T and H.
Your model uses the exact same ice maker kit and all my 3 did that I fixed.
W10882923 Icemaker
