Maytag MSD2576VEM00 Ice Dispenser Door Won't Open
patrick44107
Ohio
MSD2576VEM
My ice dispenser door won't open. The auger and everything else is working fine, but the ice gets stuck in the door each time I clear it out. Originally, I thought that it just got clogged, but have cleared the area several times.
Check for voltage at the ice chute door motor. If voltage is there, then the problem is that motor.
Here's the Ice chute door motor: W10174787 Ice chute door motor
patrick44107
Ohio
So I kind of forgot about this, but as we repairing things in preparation of selling, I opened the front up and tested the voltage to the chute motor. There is voltage there. However, I noticed the pad where you push the cup into doesn't appear to work - pressing it does not dispense water, but the water button above does. I attached a short video. Could this be the culprit since that would trigger the chute? I just wanted to double check before ordering the wrong thing.[video=youtube_share;2iFYWyN5AFw]https://youtu.be/2iFYWyN5AFw[/video]
