FIXED Maytag MVW7230HW0 has no power.
belrick
Lavonia, Ga
MVW7230HW0
Machine stopped mid cycle, I removed the water, got the top off to access the control board. Found 120V from wall plug to machine and to the main control board. No LED light on control board, found only .5 VDC from main control board to the washer control pannel.
Page 2--->DIAGNOSTIC LED – MAIN CONTROL (ACU)
A troubleshooting tool has been implemented onto the main control board—a diagnostic LED.
LED Flashing – The Control is detecting correct incoming line voltage and the processor is functioning.
LED OFF or ON – Control malfunction. Perform TEST #1: Main Control (ACU), to verify main control functionality.
Here's the ACU for your model, if needed: Cntrl-Elec W11419171
  • tech-sheet-w11197745-revb.pdf
belrick
Lavonia, Ga
Followed the steps, dinostactic LED indicator, had 120VAC at J1 Terminal, moved to J14 Terminal couldn't get a VDC reading.
Ok, that means your ACU is the culprit.
Glad to help, let us know how it goes after you install it.:)
belrick
Lavonia, Ga
Update, after board replacement machine is working fine. Anyone in the Anderson, SC area and need appliance parts. Hive Boone Appliance Repair a call. Very nice on the phone, fast turn around on the part I needed. First class. Thanks for your help Jake.
Excellent, glad to hear the new ACU fixed it.(y)
Thanks for letting us know about them in your area.:)
