Maytag MVWX655DW1 F7E5 Error
TFranco19
Beach Haven, NJ
MVWX655DW1
Hello,
I am having an issue with my Maytag MVWX655DW1 Top-loading Washing Machine. I received an F7E5 error about a month ago and found that the actuator was broken. The small plastic arm on it broke. I replaced the actuator and the machine ran great for a couple weeks. I've started getting the F7E5 error again but the actuator is not visibly broken this time. When I go into the diagnostic menu and run the automatic (or manual) test, the machine will not go into a spin cycle or agitate. The only thing that happens is the washer plate will spin once like it's trying to work correctly, but then stops.
What else could be the cause of the issue?
Check your hub first.
Here's the hub for your model:
W10528947 Hub
Here's a video to access/replace it:
--->Look at these photos below of the hub teeth grinded down to smooth. It should NOT be grinded down to smooth.
TFranco19
Beach Haven, NJ
Hey Jake,
Thank you for the response. Unfortunately, it is not the hub either. I took that out and the threading is great on it. I went back through and checked all the wiring connections under the machine and on the control board as well.
