FIXED Maytag MVWX655DW1 noise
kratt5
florida
MVWX655DW1
My Maytag MVWX655DW1 washer is making an odd noise. I pulled the agitator off and found a key. Took the key out and it sounds somewhat better. The gears/slots in the agitator looked ok. I'm attaching a video of the noise and one of it spinning normal. I attached pics of the agitator gear/teeth too. Maybe it's the transmission/gear box.
  • IMG_2166.MOV
    13.1 MB
  • IMG_2165.MOV
    5.4 MB
Yes, the 1st video sounds like the hub is the problem. Also take a photo of your transmission shaft if you could please.
Check your hub first.
Here's the hub for your model:
W10528947 Hub
Here's a video to access/replace it:
--->Look at these photos below of the hub teeth grinded down to smooth. It should NOT be grinded down to smooth.
kratt5
florida
Looks like it's the hub as you said. Hub is almost smooth. I think the transmission shaft is ok. Pics attached. Thanks!!!
Yes, I see the hub is bad, the new hub should fix it.:)
Transmission shaft still looks ok.
Excellent, glad to hear the new hub fixed it.(y)
