- MVWX700XL2
My washer is currently having problems on the spin cycle. I have been going through the steps in the technician service manual. What is happening is when I run the spin cycle it will spool up and within a few seconds of that will stop and the lid lock light will be flashing. I have ran the diagnostic mode and the only code it is throwing is F7E1 (basket speed sensor fault).
I ran it through automatic mode and the only thing(s) that didn't work was the spin tests.
I have done the tachometer mode, that checked out, so it is not the speed sensor itself, I checked for cut wires none were found, the one question I was unsure of the answer was if this model is supposed to have a counterweight, I can see the mounting holes for one, but there is not one installed. I am at the point where I need help troubleshooting, any help would be very much appreciated.
