- MLE2000AZW
Water pours out from the bottom and side of the door opposite the hinges. It only does this at the 3rd rinse. Doesn't matter whether its on normal or delicate, hot or cold, small or large load. Every solution anywhere says to check the bellows/door seal. But mine seems to be in perfect condition- not cracked, no pin holes, not moldy. I backed off the screw on the top door hinge in case it was twisting the door away at the bottom (as per a repair troubleshooting guide I found). The drain hole in the bellows is clear (I removed the little drain hose from it and cleaned some goop out of it). The main tub drain hose feels empty of objects when I squeeze it. Since the door is not clear on my model, I can't tell what the water level is during each cyle, but it seems to go through each cycle fine.
I am going out of my mind trying to figure this out.
