TimBling
- MLG2000AWW
- Maytag
- More than 10 years
I have a 15 yr old Maytag Neptune stackable unit that until recently has been bulletproof. Last month it started to stop mid cycle so replaced wax motor and control panel. That seems to fix everything.
Now this week it is having a hard time balancing the load in the spin cycle. I took the front panel of and shot a video of it with a smallish load in it. (On bigger loads it never gets into high speed spin mode as it can't self balance). In the video you can see that early in the spin cycle the tub is moving around a lot, both side to side and front and back. (Spin #1 Video). Later in the cycle it seems to have balanced things out and goes into high speed spin. This only happens on smaller loads, full loads or anything with towels, rugs and it just bangs around and never gets into high speed spin mode (so soggy items). I initially thought I had a clogged drain but took that off and it was clear. Could this be a slow/bad pump? Or shocks/struts? I'm hoping it's not bearings...
Thanks in advance
Tim
Thanks in advance
Tim
