- FAV6800AWW
- Maytag
- More than 10 years
My machine was stuck in the wash cycle and would not go into the spin cycle. I shut the machine off and tried turning the drum CCW and it would not turn at all. So I got out a 1x4 several feet long and forced it loose. Now I can turn it CCW easily and it will coast to a stop. I ran a cycle and it runs perfectly all the way through but I'm afraid this was a temporary fix.
I pulled the bottom pulley assembly off to check the one-way bearing. It was working properly. Do I need to replace the outer tub bearing? This is a later model machine that does not have the second one-way clutch for the drum on top of the bottom pulley. Is there a good writeup on this, preferably even a video?
