Maytag OTR Microwave Vent not sucking in air.
Chris Dunn
San Antonio, Texas, United States
MMV5156AAW
Recently the microwave vent stopped sucking in air over the stove. I cleaned the two bottom grease filters and replaced the top charcoal filter. Still nothing. I removed all filters, turned on the vent and can feel the air blowing out the top, just not sucking steam/smoke at all. Was working fine last month.
Chris
Vents outside or inside?
If outside, flapper stuck/sticking closed??
I can feel the air blowing out the top.
Then it is moving air.
Blower wheels greased/gooked up? Blower wheels loose? Fan turning slow....would have to be investigated.
