Maytag over the range microwave loud hum no heat
faucetfl
Spring Hill, FL
MMV5156AAQ
Maytag MMV5156AAQ ser 10146700CC lights, display and turntable work but makes loud hum and does not heat product. Any help / service manuals would be greatly appreciated.
A copy:
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Checking the high voltage...
http://www.applianceaid.com/micro7.html
Magnetron
