Maytag Over the Range Microwave question
eoneal22
houston
MMV5207BAB
Maytag over the range microwave
Model # mmv5207bab
SN: 10854723jt
Wierd Issue - When you close the microwave door, the microwave starts to run (without magnitron firing) without pushing any buttons. The internal tray is rotating. The microwave will not cook until you put time on the control panel and hit "start". I have unplugged the unit and left if off for several hours. Any clue on this one? Is this a door closed switch gone bad?
If I do replace the microwave with another brand, do they use the same mounting bracket that is on the wall mounted?
Thanks for your advice in advance!
When you close the microwave door, the microwave starts to run (without magnitron firing) without pushing any buttons. The internal tray is rotating. Any clue on this one? Is this a door closed switch gone bad?
Most times yes this is a door switch/door switch wire/door switch mechanism problem....odd time a relay on the smart board may be welded closed but that is rare and a door switch problem is much more common.
Most times never! New unit = new/different brackets.
