Maytag Performa - Need to diagnose strange noise
JBrown
Virginia
PAVT234AWW
Hello All!
Our washing machine is making this strange noise once in the spinning cycle. I've checked the pump, no clogs and seems to be working fine. I've checked the belt and pulleys, all is well there too. The noise seems to be coming from the center area where transmission is. Can anyone help me diagnose the problem? You can view a video recording i took of machine making the noise here: https://www.youtube.com/watch?v=ykIFuw_BktU
Thanks in advance for your help! JB
Ok JB, saw the video, lets remove the belt then put it in spin and see if that noise remains.
You did turn all your pulley's and made sure they turned smoothly and freely?
JBrown
Virginia
Indeed, I turned all the pulleys and everything runs smoothly. I did this lastnight before the video clip... I took the belt off, made sure belt was fine, turned pulleys and all is well there. I then put belt back on and ran spin cycle only... and the video shows the results. I'll try again tonight running the spin cycle with belt off and post results. Thanks!
JB
Ok JB,
Yes, post back tonight the results of running the spin cycle with the belt removed.
JBrown
Virginia
I took the belt off. No noise. engine pulley was spinning fine. So are talking something in the transmission system?
Possibly yes, but watching that video again makes me thinks its the water pump, either something is in it or the water pump bearing is making that noise. Because the noise seems faster than the transmission is spinning.
So I'd first remove the water pump and check for something inside it.
