Maytag Range PER5750QCW Outer Glass 74008681
Binwa
Montréal
PER5750QCW
I shattered the outer glass on my Maytag range. The part, number 74008681, is apparently discontinued. I checked numerous used part stores around me, online...can’t find it anywhere, help!
The range is working super well, I don’t want to change it...any solutions? Can I use another equivalent part?
Thank you!
I can't locate any stock of that part either. There is a bisque version of that range model that uses glass # 74008682 that will fit on yours, just be a darker color. While it is NLA too, I did find a couple up for auction.
LINK > Outer Door Glass # 74008682 / 74008681
Other than that, a glass supplier can have a piece of clear glass cut and then temperated if you supply the dimensions. You can then hand paint it... or not. At least it would allow you to continue to use the range safely.
Binwa
Montréal
Thanks Dan O.
I looked online and it’s complicated as I’m in Canada but I don't mind the weekend trip to the US given that I’m not too far from the border.
I’ve also seen online that part WPW10160908 in black might also work.
Possibly. I didn't see a black version of your particular model so didn't come up with a number for a black glass.
