RobertRobert
- MFI2067AES
- Maytag
- 6-10 years
Hi everyone
We have a Maytag double door upper with freezer lower drawer. Recently the ice and water dispenser stopped working and the fridge got warm Ice was melting, Called repair man. Guy found a leaking freon line across the water pan on the bottom. He cut the piece out resoldered new section, recharged and fridge cools fine. Everything is back to working as far as cooling and making ice except for the dispensing issue.
so....the ice and water dispenser do not work. When i press the dispensing paddle there is no ice or water being dispensed. I downloaded the service manual and went through the diagnostic sequence. When I use the display/keypad to go to the individual section to test the individual functions the water dispenses, the ice dispenser and the motor/paddle moves to allow ice to drop down. So I’m getting ice, water and the flapper to open as long as I’m in the test mode. Once I go out of test mode those functions don’t work.
could the filter be clogged up? is it the board? but that doesn’t make sense if it works in test mode. Is the board available used or does anyone have a board? Can it be fixed?
thank you for any help.
