FIXED Maytag Refrigerator MFI2269DRM01 - Fridge warm, freezer cold
johnndyinMS
Mississippi
MFI2269DRM01
Replaced the main control board WPW10312695 on this unit to fix ice maker. First time having it all plugged in (it’s in a motorhome that’s in storage unplugged often). Freezer is cold. 6 degrees after a few hours plugged in. Fridge is warm. 70 degrees after a few hours. Fan just inside back bottom panel is spinning fine. Can’t see any frost outside. Not sure how to access any other compartments inside. Lost.
johnndyinMS
Mississippi
Overnight, a digital fridge thermometer reads 58, down from 66 last night. That normal? Only air coming in seems to be from the chiller slider on the right side of the cabinet.
Should be colder than that. Why did you replace the board? Is the condensor fan and evaporator fan working?
johnndyinMS
Mississippi
Icemaker was not getting voltage and would not cycle. At your recommendation, I tested the voltage on the board and got 1.73 across J1-8 and J2-8.
Looked again this morning. I don't think the ice maker fan is blowing. No air coming through the vent where the damper control is. Damper control stays shut (though it moves freely by hand).
Run service tests #112, #113, and #121 in service mode.
Service Mode:
1. Press and hold the Door Alarm Keypad.
2. Press and hold Refrigerator Temperature UP / + Keypad.
3. Release the Door Alarm Keypad and wait 3 seconds.
4. The Freezer display will display SE confirming entry in the Service Mode.
5. Press the Refrigerator Temperature UP /+ Keypad again to confirm entry in the Service Mode.
6. Display will show 101 in left display and numeric or dashes in right display.
7. Press Freezer Refrigerator Temperature UP / + Keypad and Freezer DOWN /- Keypad to toggle through Service Test numbers.
8. To exit service test mode, open and close refrigerator door or hold door alarm for 3 seconds.
Service Test – 112 Freezer Fan
Press the Refrigerator Temperature UP /+ keypad and Refrigerator DOWN /- keypad to toggle Freezer Fan On High speed, Low speed and Off.
NOTE: Display will show state 0.0 for OFF, 11.0-14.0 V for High speed or 7.75- 8.25 V for Low speed.
Service Test – 113 Ice Compartment Fan
Press the Refrigerator Temperature UP /+ keypad and Refrigerator DOWN /- keypad to toggle Ice compartment Fan On High speed, Low speed and Off.
Service Test – 121 Damper Operation
Press the Refrigerator Temperature UP/+ keypad and DOWN /- keypad to toggle Damper OP open and CL closed.
NOTE: If damper is opening or closing, it will not allow you to toggle damper and beep. Display will show state –CL or –OP if Damper is in the process of closing or opening.
