FIXED Maytag Refrigerator MFX2571XEB2 Water Issues
Craven
Iowa
MFX2571XEB2
Having issues getting the water dispenser and the ice maker to work. It's a Maytag MFX2571XEB2. I've replaced both water valves (the main one where the water connects and the one inside that splits off to the door and the ice maker). When the water dispenser button is pressed, the main water valve is working and supplying water up to the inside valve. If I unplug the connector going to the drinking water valve and press the button, I'm getting 120v across the 2 terminals. However if I plug it back in and press the button, I'm getting 0v. I'm guessing the ice maker is doing the same thing.
Hoping someone can point me in the right direction from here.
It sounds like have what's called ghost voltage, its like you have a bad neutral connection, but I've never seen this happen on a refrigerator that's 120 volts. I have seen this happen on 2 dryers where its 240 volts.
Look for a broken or shorted neutral wire in your water inlet valve wire harness.
I'm attaching your wiring diagram below, the WH(white) is NEUTRAL. You can see from the SMART VALVE P1-2 YL and P1-3 TN goes to the WH(white) NEUTRAL side.
  • techsheet-w10341191-revb.pdf
Craven
Iowa
You sir are a lifesaver. I traced the neutral back using the schematic, and somehow, in the connector up in the light housing, one of the white wires has wiggled out just enough that it was no longer making a connection. No idea how this happened. Saved me buying a new fridge.
Thanks again!!!!
Excellent @Craven glad you found the bad neutral and fixed it.(y)
