phosphorelated
- PBF1951KE
- Maytag
- More than 10 years
I bought my fridge with my house a little over a year ago, and it was working fine when I moved in so I never changed the temp setting. This morning I noticed things in the fridge weren’t as cool as usual, so I checked the freezer and the contents were still cold but not frozen. I could feel cool air blowing into both the fridge and freezer compartments.
As suggested in another post on this topic, I cranked down the temp (from setting 3 to about 5). I moved the fridge away from the wall, and removed the back access panel. The fan and compressor were running; the air the fan was blowing was cool, and the compressor was warm, but not hot. After a while, the compressor became noticeably hotter, and the air the fan was blowing warmer, I assume in response to the changed temperature setting).
There was a ton of pet hair compacted in around one side of the compressor, and I immediately removed as much as I could with the fan running (pictures of before I pulled it out, and the grocery bag full of stuff I removed attached). A few hours later, I unplugged the fridge for about half an hour to vacuum out some more stuff, and in that time the fridge got up to 50 degrees (according to a probe thermometer; I’m keeping the doors shut as much as possible), but has since cooled back down to about 42.
Since the fan and compressor seem to be cycling on and off, and the fridge is clearly cooling some, it seems like the compressor relay is ok. What I still don‘t know is why the fridge and freezer suddenly weren’t cooling as well as they had been, or what to do about it, aside from cranking down the temperature setting. What should I check, and what else can I try? Thanks!
