Maytag Top Load Rinse/Fill During Last Seconds of Spin Cycle - Clothes Wet
NTL1991
Rhode Island, USA
MVWC6ESWW1
Hello,
I just went to switch items over from my washer, and I found my linens soaking wet at the bottom of the tub. I ran the spin cycle again, left the washer, and came back to wet linens again. I (again) ran the spin cycle, but observed the washer all the way through.
The spin cycle is starting fine, the drum is coming up to the proper speed, water is being pumped into the standpipe, and the water is being spun-out completely as you can hear the volume of water decreasing as the cycle progresses. The problem is that at the last 10 seconds or so of the cycle, the fill valve opens, and wets the spun out clothes. The spin cycle stops, and the valve closes, leaving the clothes soaking wet. The fill valve is not leaking when the washer is off.
The washer is a Maytag Centennial, MVWC6ESWW1 top-load washer. I had a problem at 8 months old where the washer would immediately start agitating when the cycle was started, rather than waiting to be filled. I believe it was the load sensing switch which was replaced. Now it's about to 2 years old, and I've got this problem.
It sounds like a bad timer to me, but knowing all of the sensors and switches in these things, I don't just want to throw $125 just to find out it was a bad water level sensor or some random thing like that...
It's funny, but I purchased the exact same model for my tenant 6 months prior to purchasing the one in question, and it hasn't needed a single repair, however, they don't use it half as much as I use mine,. My old washer, a 12 year old Inglis, has never needed a single part replaced and was used just as frequently as the Maytag in question (a load every other day), and is now used by my other tenant with no problems. Are parts longevity a problem with Maytags? If so, I guess I was easily fooled by the marketing.
Nick
Thats likely the same part you replaced 2 years ago.
The main reason it keeps going bad is if the lid switch is opened without first shutting the timer off, it will arc the sensor switch and cause premature failure.
NTL1991
Rhode Island, USA
Thanks for the good information.
Because I can't imagine that the problem is being caused by an electrical issue external to the switch itself, I think I will swap the known-good temperature switch from my other MVWC6ESWW1 and observe a cycle. That would tell me for sure if the switch needs to be replaced. Before that, I'll check to see if it's agitating before filling up as well. I just ran the spin cycle, so I'm not sure if it's doing the exact same thing as before.
I always refrain from opening the lid during the cycle because doing so automatically adds more water to the drum, which goes against the whole reason why I bought a water-saving washer. It seems to me that the switch might be manufactured a little too inexpensively... I wonder how the actual commercial-grade Maytag units fare against switch failure.
Thanks Jake,
Nick
NTL1991
Rhode Island, USA
OK, So I started a cycle today and the agitator started immediately. That's the same problem I had before, and I'm pretty sure it was the load sensing/temperature switch. I'm going to order it now.
Nick
Ok Nick, yes order it and keep us posted.
daveschmittjr
Alabama
Follow-up
Nick
So what part was responsible for this problem?
David
