Maytag Washer Error Codes F06 and E02
Spankster301
SC
MHW7000XG0
I have a Maytag Model # MHW7000XG0 The stopped working last night a showed the following Error Codes - F06 and E02. Can anyone help me out with these error codes? All help will be greatly appreciated.
I'd check your MCU for any burnt spots on it first. That's usually the case for the F6E2 error code. There is a video in the MCU part link that shows how to remove and replace it. Unplug your washer first! Then take the plastic casing off of the MCU board and check the entire MCU board for burnt spots on it.
Here's the MCU board for your model you can order, when you click the link to it you will see many others that had this same F6E1 and F6E2 and it fixed theirs:
WPW10374126 Motor Control Board
