Maytag washer fills then stops
jhealy50
New Hampshire
Maytag Top Loader, Model LAT8705AAE. The washer filled part way and that stopped - nothing worked after that. Noticed the fuse was blown and replaced it. Now fills according to setting but still stops after washer is filled. Continuity across lid switch changes with lid opening/closing. Not sure about the check switch as I could not get the continuity to change there.
Not sure if I am checking across the correct terminals.
Any help would be much appreciated. Thanks.
Here is the check switch:
Pegi at Sams
Wichita Falls, Texas USA
I do not know these washers but have read in the forums that the whole lid switch assy has to be replaced that includes the fuse, seems there are two switches in that assy? I may very well be wrong about this however..:confused:
